rispgiu Posted June 12, 2019 Share Posted June 12, 2019 I am working on a layout plan and I was wondering if there is a way to show the porches on the foundation layer (Floor 0)? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 12, 2019 Share Posted June 12, 2019 Reference Display Link to comment Share on other sites More sharing options...
rispgiu Posted June 12, 2019 Author Share Posted June 12, 2019 29 minutes ago, Alaskan_Son said: Reference Display Thank you! Generally I use the reference display trace the porch with cad lines but I guess I was wondering if there was a better, easier way. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 13, 2019 Share Posted June 13, 2019 4 hours ago, rispgiu said: Thank you! Generally I use the reference display trace the porch with cad lines but I guess I was wondering if there was a better, easier way. I wasn’t trying to suggest that you trace anything. I was suggesting you use the reference display—period. Just set it to use the appropriate floor and then set your reference display layer set to only display the appropriate item(s). 1 Link to comment Share on other sites More sharing options...
rispgiu Posted June 13, 2019 Author Share Posted June 13, 2019 56 minutes ago, Alaskan_Son said: I wasn’t trying to suggest that you trace anything. I was suggesting you use the reference display—period. Just set it to use the appropriate floor and then set your reference display layer set to only display the appropriate item(s). I wasn't aware we could do that. Thank you very much. I'll look into it. Link to comment Share on other sites More sharing options...
