sorento Posted May 26, 2019 Share Posted May 26, 2019 Hello I need use in the attic a wardrobe or any cabinet under sloped ceiling, Is it possible in Chief Architect? My roof is 35 degrees. regards Link to comment Share on other sites More sharing options...
MarkMc Posted May 27, 2019 Share Posted May 27, 2019 1 hour ago, sorento said: Hello I need use in the attic a wardrobe or any cabinet under sloped ceiling, Is it possible in Chief Architect? My roof is 35 degrees. regards It can be done with a good bit of work (this took about an hour with some fiddling involved). You need to use custom door symbols for the front (just a polyline solid converted) and another for the back (used psolids converted to solids, then solid subtraction). In boht cases the size needs to be locked (look at the stretch planes in the samples) and the back needs the origin adjusted and the symbol rotated. For every size you will need a symbol for each that has it's size locked by setting the stretch plains. To make new symbols you can reuse the first symbols by placing in a plan and changing the stretch planes for height. IF you need different widths you will have to start from scratch though or the angle will be off. Sample plan with parts used and sample symbols. Cabinet included to see how it's configured is used. NOTE had to use a base cabinet to make this work, a full height doesn't. You may want to read up on symbols in the reference manual if you're not familiar with them. I should add that the solids include might be backwards and that when making a solid for the front door it should be the reverse of what you want. Symbol always seam dyslexic to me which adds time as I never remember exactly which way for go. Angle cabinet.plan 1 Link to comment Share on other sites More sharing options...
sorento Posted May 27, 2019 Author Share Posted May 27, 2019 thank you very much This is more difficult than I thought. I think that the program should have the function "cut (trim) to the roof (ceiling), etc.) Now it is a basic option in professional CAD programs regards Link to comment Share on other sites More sharing options...
MarkMc Posted May 27, 2019 Share Posted May 27, 2019 2 hours ago, sorento said: thank you very much This is more difficult than I thought. I think that the program should have the function "cut (trim) to the roof (ceiling), etc.) Now it is a basic option in professional CAD programs regards The easy (sane) way is to just use p solids for 3D and/or a CAD detail (from view) for 2D. I don't know of another program that can trim a cabinet symbol, maybe Sketch up if exploded? Link to comment Share on other sites More sharing options...
sorento Posted May 27, 2019 Author Share Posted May 27, 2019 I was thinking about Archicad. I worked in this and I associate this option but I am not sure now if the cabinets were also trim. Quote The easy (sane) way is to just use p solids for 3D and/or a CAD detail (from view) for 2D. Is there any tutorial? Link to comment Share on other sites More sharing options...
