CA-Balmoral Posted May 16, 2019 Share Posted May 16, 2019 Hi, This may be a dumb question, but ... is there an option that we can Auto Ext Dim to 'CENTER of the layer' specified in Wall Type Definitions' Dim To setting ? in this simple example : 1.925m is a typical auto dim. while 1.82m is a manually achieved! Thanks for any advice. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 16, 2019 Share Posted May 16, 2019 No that is not likely an auto dimensioning possibility without severely messing with your wall definition which would likely cause other issues with your build. However you can Auto dimension and then frame and manually snap to the centers of framing. I have not seen that request before and curious as to the purpose of it ? Link to comment Share on other sites More sharing options...
