dfn001 Posted April 29, 2019 Share Posted April 29, 2019 I have searched without any luck to locate a wall connection problem that is causing my plan to have an exterior room. Short of starting over with my exterior walls is there any way to locate where the problem occurs? My model is extremely large so I don't think I can post it but if needed I will try. I am using X11. Link to comment Share on other sites More sharing options...
dfn001 Posted April 30, 2019 Author Share Posted April 30, 2019 Thanks for the reply. I was not aware that all plans have an exterior room. The problem I am now having is that the soffits on the box eaves seem to be extending way too low from the rafter framing. I was thinking that the exterior room was causing this problem. Link to comment Share on other sites More sharing options...
tommy1 Posted April 30, 2019 Share Posted April 30, 2019 Check your sub fascia height. Link to comment Share on other sites More sharing options...
