Flatland
flatland
Select tool. I can highlight every room on the first floor to get to room specification box, but cannot select any room on second floor of home floor plan. I have checked to see if anything is locked.
Any suggestions on what to look at?
Please fill out your signature with the software you are using, also Computer info would help. Go to your profile, select it, select account settings, then in the next drop down menu, select signature. Be sure to make it viewable.  You should check to be sure you have no walls set as no room definition.
(Edit) Eric beat me too it! I assume all your walls are connected too?
