Object line change from plan to layout
doitright
I am working on a commercial plan and some objects I would like to appear with dashed outline on the reflected ceiling plan. It all looks like I want it in working plan view but when exported to the layout they come up as solid lines same as are on the floor plan. Is there a trick i am missing? Using X8
Thanks for any replies
In Layout, select the view you're having problems with;
Click on the Layer Set Options;
Select the same Layer Set as the one in plan view that looks correct. (that you thought you sent to Layout);
That should fix it so you're seeing the same lines as the one in your plan view.
    31423
    jomax77
    jomax77
