Rashid_Garuba Posted March 8, 2019 Share Posted March 8, 2019 Using X10.. I have several mulled windows and in the saved Cameras you can see between then windows.. Not happened before. Can someone take a look..? Thanks Office II.plan Link to comment Share on other sites More sharing options...
javatom Posted March 9, 2019 Share Posted March 9, 2019 I see that on my end also. It is interesting that a fresh camera shot does not have the problem, only your saved views. Link to comment Share on other sites More sharing options...
javatom Posted March 9, 2019 Share Posted March 9, 2019 The layer set that those views are using has the layer "casing, exterior" turned off. If you turn it back on, it will be there. Link to comment Share on other sites More sharing options...
Rashid_Garuba Posted March 10, 2019 Author Share Posted March 10, 2019 Thanks guys.. Its the casings layer I will leave on.. even though the windows have no casings the Mulls are on that layer. Link to comment Share on other sites More sharing options...
