GZankey Posted February 20, 2019 Share Posted February 20, 2019 I just installed X11 and the only file that migrated was the users library. I haven't made any customizing. Would it make sense to re-install and try again? Link to comment Share on other sites More sharing options...
Kbird1 Posted February 20, 2019 Share Posted February 20, 2019 1 hour ago, GZankey said: I just installed X11 and the only file that migrated was the users library. I haven't made any customizing. Would it make sense to re-install and try again? The Core libraries you mean ? or the Toolbars,textures and everything else is missing? did you check everything in the migrate dialog? you can force it to re-run but a reinstall on it's own won't do it, you need to rename or delete the .ini file 1st. see below Link to comment Share on other sites More sharing options...
GZankey Posted February 20, 2019 Author Share Posted February 20, 2019 I just re- installed before you commented, and the migration dialog didn't even appear. I have everything but the core libraries & manufacterer. When I first installed I thought all the boxes were all checked. Dang it. Now what? Link to comment Share on other sites More sharing options...
Kbird1 Posted February 20, 2019 Share Posted February 20, 2019 16 minutes ago, GZankey said: I just re- installed before you commented, and the migration dialog didn't even appear. I have everything but the core libraries & manufacterer. When I first installed I thought all the boxes were all checked. Dang it. Now what? See above as I mentioned ...you were tooooo quick on that reinstall it can also be done manually if needed , there are Tuts. in the KB. M. Link to comment Share on other sites More sharing options...
GZankey Posted February 20, 2019 Author Share Posted February 20, 2019 I got Tech Support on the phone and I'm all set. Great tech guy! Thanks Link to comment Share on other sites More sharing options...
