jhall1 Posted February 6, 2019 Share Posted February 6, 2019 I am trying to adjust the height of log siding from 10", the default height, to 7 1/4", the height of our logs. I've reset the height in the Define Material settings to 7 1/4", however in camera view the logs are shown as 10". I am currently using CA x7. Thanks Judi Link to comment Share on other sites More sharing options...
Kbird1 Posted February 7, 2019 Share Posted February 7, 2019 3 hours ago, solver said: Are you asking about patterns (vector views) or textures (standard views)? You cannot simply set a texture to a specific size. It needs to be scaled up or down. If it's the Texture you need to adjust the Texture size TOO , not just the size on the General Tab, eg if the texture shows 5 logs vertically make the texture size 36 1/4 high and maybe double that long so the repeat isn't too obvious..... If you need more help that that post a Plan File which includes the Materials you are using.... Link to comment Share on other sites More sharing options...
jhall1 Posted February 7, 2019 Author Share Posted February 7, 2019 Thanks! I didn't realize I had to set the scale as well as the height. All set now. Link to comment Share on other sites More sharing options...
