Chrisb222 Posted January 25, 2019 Share Posted January 25, 2019 I noticed some of my Core Catalog materials were missing their textures. When I investigated, I found that some of my Materials are getting their textures from older Chief versions, even from before that, back when I originally used HD Pro. Is this normal? If not what am I doing wrong when I upgrade, and how can I force all the current materials to use X10 textures? Does it matter? I went to merge duplicate plan materials in my template plan, but doing so would keep the first duplicate in the list and many of mine refer to an older texture file in the first instance, and X10 texture file in the second instance. It seems if I merge duplicate plan materials I would want the material that uses the most recent texture...? Thanks Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 25, 2019 Author Share Posted January 25, 2019 Nevermind, realized I need to run Library > Update Library Catalogs. Duurr That corrected a lot of my problems but still have a lot of manual cleanup to do. Apparently I've introduced a lot of confusion in my materials by not doing that with each upgrade. I'll be sure and do that from now on. I'll leave this thread here Justin Case it helps someone else. Link to comment Share on other sites More sharing options...
