Rafter Cuts
EvanMW
Adding pics to the Thread with the Windows Snipping Tool will help greatly others answer your questions, adding the Plan File is even better.
Also at some point please do you Forum Signature so we know what software you are using.....
I am using the X10 version. Maybe this is easier, on a dutch hip the gable extensions extend past the roof plane into the hip portion of the roof, they are not flush with the roof plane. There should be an option to trim the sub fascia with the roof plane. Even if i didn't need dimensions it still looks bad sticking into the roof 6".
Not quite sure what the issue is, but if the wall extends too far, pull it back manually......
see the Blue below to do your Sig. and enable them Forum wide.....many questions have different methods depending on the Version used and it saves you posting your version for every question.
Mick
*** to fill in your Signature like this .... go up to the top RH Corner above and click on your UserName> Account Settings> Signature.... and enable Signature (will Turn Green) then add your Hardware Details and Chief Software Version, as different Version require different Answers.
***To add Pics to your Posts please use Windows Snipping Tool , found under Windows Accessories in your Start Menu, Save the Snip to your Desktop and Drag it into the Light Grey Area of the Reply Window.
