Inverting and object
lockwood
  I drew this column and realized too late that it's upside-down. I am looking for advise on how flip it. I tried "Reflect about an Object" but had no luck. Any suggestions would be appreciated. Unfortunately I no longer have my original profile tracing.
As Eric said you can Rotate the Symbol if indeed it is a Symbol , however looking at the Pic it appears to be in the correct orientation going by the tapering of the center section....no ?
Thank you for your response.
Yes, strangely enough the taper points down rather than up and that is exactly how I made the mistake. The column is for an old Victorian house and the longer square end is meant to be on top in order to accommodate a spandrel.
It is a symbol but, unless I'm missing something, I can only rotate it horizontally. I cannot seem to flip it.
