NeilofOZ Posted January 8, 2019 Share Posted January 8, 2019 Have a house on piers and bases only with no stem walls, but will require a decking totally surrounding the structure. Have created the main house as per attached as it's a simple rectangle, but having issues setting up the floor framing. Have set "grade beams on piers" in foundation default menu. At this stage it still shows a perimeter stem wall which I cant delete and don't want. No floor framing is shown even though I have them displayed. The positioning of piers and bases are too cryptic to understand. Do I just create a decking from the start and add the house walls on top. Neil. Tracey's House Plan.plan Link to comment Share on other sites More sharing options...
justmejerry Posted January 8, 2019 Share Posted January 8, 2019 Neil will you be using wooden beams to carry load on the piers? If so, I would personally just do manual beams and piers on level 0. More control in placement. Link to comment Share on other sites More sharing options...
