Lee05491 Posted December 28, 2018 Share Posted December 28, 2018 I'm designing a high performance home with 10-1/2" exterior walls. I've modified Chief's single casement window style to accommodate Euro-style tilt-and-turn windows to give a "close enough" look. Then followed Chief's instructions for placing them in thick walls. Unfortunately, C A only allows straight through openings. I want the side openings to flare at 30 degrees. Ideally, I'd like to create a Library object that I can repeat, perhaps even scale. I use 4 different size windows now. Link to comment Share on other sites More sharing options...
Lee05491 Posted December 30, 2018 Author Share Posted December 30, 2018 Hi, Eric- Thanks for the suggestions. Unfortunately, I'm on a Mac and cannot read B.zip files. Can you resend as a PDF file? Thanks. Lee Link to comment Share on other sites More sharing options...
glennw Posted December 30, 2018 Share Posted December 30, 2018 The .zip file opens on my mac - it's just an ordinary .zip file. It shows up as Angled Window Recess B.plan in Downloads. I didn't do anything special. Just downloaded the .zip file and it displays as a .plan file in Downloads. You could have a look at this setting which I have toggled on. Open Safari Click Preferences Under the General tab, check the option Open “safe” files after downloading Link to comment Share on other sites More sharing options...
