MickeyToo Posted April 12, 2015 Share Posted April 12, 2015 OK. I have done text macros before without a problem, but it is not working in the case of a polyline. When I create the (area) macro in Text Macro Management, everything is fine as long as I designate is as an Owner Object, but then it is not available for use in a Text Object. If I designate it as a Reference Object, I get an Evaluation Error. Any ideas as to what I might be doing wrong in this instance? Link to comment Share on other sites More sharing options...
GerryT Posted April 12, 2015 Share Posted April 12, 2015 Can't tell from your image or description what you are trying to do? But a owner object macro can only be used with a selected object as within a label. Polylines do not have labels. A reference macro can only be used in a textbox with arrow leader. If you use owner or reference in the wrong application, you'll get a error -- unless you "catch" the error. Need more info. Link to comment Share on other sites More sharing options...
MickeyToo Posted April 12, 2015 Share Posted April 12, 2015 Thanks, Gerry. I am all set for now. I may post on this again latter. Link to comment Share on other sites More sharing options...
