KAustin Posted December 18, 2018 Share Posted December 18, 2018 When I created my home plan i first imported my topo which was in .DWG format. I copied my floor plan that I had an architect create that was also in .DWG and put it to scale. I did the first floor and the second floor and gave it a foundation, retaining walls etc. The problem i have is the property is a sloped property and the second floor is actually the main floor and should be at elevation 0". When I try to make the changes to the elevations all of the floors get jumbled together and i can't get them to the right elevations. Randall_Highgate_Elevation_Mod.plan.zip Link to comment Share on other sites More sharing options...
rlackore Posted December 18, 2018 Share Posted December 18, 2018 Chief Architect places Floor 1 at 0'-0". You cannot change this default behavior. You can, however, set the Terrain Perimeter elevation relative to Floor 1 within the Terrain Specification dialog box: Link to comment Share on other sites More sharing options...
