JanHalter Posted December 5, 2018 Share Posted December 5, 2018 Hi there! I have been searching for a bit, and attempted a few things to no avail. Anyone have a step by step tutorial (or is it just not possible?) on how to at the very least import an existing title block from Revit or CAD to Chief? I am far from proficient in Chief at this point and wondering if it's possible. We want to make sure the title block matches our Revit sheets exactly...in case we have to draw something in one program vs. another in the same CD set. I tried exporting to .dwf from Revit and importing into the layout page, however it doesn't allow me to import that file type into the main layout page. Also, am I blind? I can't figure out where to put my signature...so I just typed info below. Janea Rafter P Construction Cheif ArchitectX10 Link to comment Share on other sites More sharing options...
rlackore Posted December 5, 2018 Share Posted December 5, 2018 You can import DWG or DXF into Chief, so export from Revit using one of those two formats: Link to comment Share on other sites More sharing options...
rlackore Posted December 5, 2018 Share Posted December 5, 2018 If you want to import a full layerset, you'll need to create a Revit drawing with at least one entity (can just be a simple line) on each Revit layer. Then import into Chief using the Import Drawing Assistant (File>Import>Import Drawing (DWG, DXF...). As you go through the steps, check all the layers you want imported: ...and map the layers to Chief Architect layers by name: Then delete all the useless geometry that was imported, and you're left with the layers as they were set up in Revit. Be aware that line weights, line styles, etc. may need adjustment within Chief. You can also massage some of the export settings within the Revit export setup: Link to comment Share on other sites More sharing options...
rlackore Posted December 5, 2018 Share Posted December 5, 2018 How to add your signature: Link to comment Share on other sites More sharing options...
