StevenYaple Posted September 3, 2014 Share Posted September 3, 2014 Is there a special symbol for a recessed eyeball light? Thanks. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 3, 2014 Share Posted September 3, 2014 I don't think so - but you can adjust the angle of the light source for a recessed can or mini-can. That should provide the lighting effect that an eyeball light would provide. Link to comment Share on other sites More sharing options...
JLDrafting Posted September 3, 2014 Share Posted September 3, 2014 CA core catalog> Architecture> Lighting> Recessed. Link to comment Share on other sites More sharing options...
StevenYaple Posted September 3, 2014 Author Share Posted September 3, 2014 Thanks for the responses. I was looking for a plan symbol that would differentiate it other than with the label. The homeowner/designer may want to see an eyeball but I'm not sure that should be necessary. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 3, 2014 Share Posted September 3, 2014 You can just edit the 2D Block to whatever you want the Plan Symbol to be. Link to comment Share on other sites More sharing options...
StevenYaple Posted September 3, 2014 Author Share Posted September 3, 2014 I was able to create a 2d block and change the 2d block for a single light - is there a quick and easy way to create a light symbol that uses that 2d block? I have 21 of these lights. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted September 3, 2014 Share Posted September 3, 2014 Just put the one you edited into your "User Library". Then use that one instead of the one Chief has. Link to comment Share on other sites More sharing options...
