nvirgilio Posted November 16, 2018 Share Posted November 16, 2018 Hello everyone, I have a half wall intersecting an exterior wall and is supporting a peninsula bar top on the left side of a u-shaped kitchen. The design works out that the left end of the wall cabinet on the exterior wall lines up with the inside corner of that wall intersection and causes the left side crown molding to disappear as if the cabinet abuts the "upper" portion of the half wall. If I make the half wall invisible, the crown shows correctly in both elevation and perspective views, but is not an acceptable solution. If I shrink the cabinet width by a 1/2" the crown appears correctly, but then my sizes and dimensions are off. Any suggestions? Thanks, Nick Crown issue - Chief.pdf Link to comment Share on other sites More sharing options...
MarkMc Posted November 16, 2018 Share Posted November 16, 2018 I use molding polylines as Eric suggests (for a lot of reasons) but if you really don't want to- delete the wall, the shift select the cabinet and make architectural block. Redraw the wall, molding won't change once cabinet is blocked. Link to comment Share on other sites More sharing options...
