toller65 Posted October 23, 2018 Share Posted October 23, 2018 Relatively inexperienced user here, needing some help with deleting a roof over an addition that i no longer want to add. Home Designer Suite 2015, Build 16.4.1.20x64 Plan is attached, need some suggestions on how to delete the roof that is now hanging in the air over what was a proposed addition. When I try to edit the roof, it either deetes the dormer and gives me an angled roof on the right end, or it completely gre-generates the roof inot something unrecognizable. Any insight would be greatly appreciated. Thank you! 22Oct2018_Project.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 23, 2018 Share Posted October 23, 2018 Only Home Designer Pro has the manual ability to edit roof planes. As Eric has indicated, in Suite all you can do is to alter Wall Specification Dialog - Roof Tab settings and other Structural Tab settings and then rebuild roofs or you can upgrade to HD Pro that does have manual roof editing abilities. DJP Link to comment Share on other sites More sharing options...
