Plan Views- why bother, avoiding problems, and getting around inability to import.
MarkMc
Why mess with Plan Views- Annotation sets are great but they don’t save the actual view or floor, plan views do.
You can have several plan views with the same annotation set, some for changing floor levels, some for zooming in closer, showing reference display or not.
You can have a plan view that uses all of the annotation defaults with a different layerset.
Opening a plan view from the project browser creates a new tab with the plan as you saved that view.
I’ve had to set up templates for several clients, each with some changes. But you can’t import plan views. I can start with a template with some but sometimes need others or changes.
Few things I’ve found useful. All are almost the same procedure.
Setting them up fresh and making new ones easily
  • Import annotation sets and layersets you think you will need (I have a few variations saved for this).
  • Plan view tied to annotation set-Select an annoset and zoom view to about what you will need on the floor you want. Click “save plan view” and name it.
  • Same view and annoset on another floor.- While in that plan view click “new plan view”. You’ll get a new tab with the same view and anno-set etc. Change the floor THEN click Save Plan view and give it a name. Repeat as needed.
  • Same view with different annotation set. -In a view you want Click New Plan View, get new tab, change annoset. Save plan view, give it a name.
  • Same view, same annotation defaults, DIFFERENT layerset. From view, click new plan view, get new tab, change layerset only, save plan view.
  • By now you should get the idea.
To protect my plan views and avoid confusion. Move the “Save Plan View” icon out of the way so you don’t accidentally or automatically click it. Then add icons for “New Plan View” and “Save Plan View As” where you will easily find them. If you use hotkeys make the key combo for “Save Plan View” dissimilar to the other two and more challenging to reach. Something like- S,N for New Plan View; S,A for Save Plan View As, (both one handed) and Z,P (two hands for most folks) for Save Plan view.
Finally-
  1. Upon opening a plan, open a second plan view. Change something in one of these, doesn’t matter what or which one. Then close it.
  2. When the little DBX pops up with “This saved plan view has been modified since it was last saved. Would you like to save the current settings?”
  3. Check off “Remember m choice during this session” and select NO. That way when you close the plan you won’t accidentally click yes and screw up your plan view.
I’m teaching my clients to do this last bit since they don’t want to mess with all the other complications and I don’t want them returning plans with messed up layouts.
    30186
    AshleyH
    AshleyH
  • Similar Content
    • By SNestor
      So...I'm listening to a webinar yesterday that Dan at Chief Experts/Pro Academy was holding. The topic was new features in X10.  Seems like a topic you would do in March...but so be it.
      Early on he covered "Plan Views" and made the categorical statement that to him this feature didn't do much for him.  I was a bit shocked...as I use this feature all the time...and have found it to be very useful...but, he has been using the software much longer than I have and maybe is "set" in the way he uses the software.  One thing I've noticed about Dan is that he doesn't seem to use "annotation sets" much either...and if you aren't really using "anno sets" then it's somewhat logical you'd not be using plan views either.
      For me...being able to assign a specific "reference set" to each plan view is incredible.  This feature alone makes "plan views" very powerful.
      Just wondering what the consensus is....are you using "Plan Views" in your day to day work flow?
      Thanks
    • By lavorhaynie
      Just installed X10. Getting my feet wet learning about "Plan Views". Watched videos, scanned ChiefTalk, read help files.
      I use legacy plans for about 80% of my work. Is there a way to import plan views into pre-X10 plans?
      Thank you!
      LaVor Haynie
      Been Chiefin' since 2004...
    • By SNestor
      I've begun to manage "plan views" in X10.  This is a really great new feature...but, the OOB settings are only a start...not the total picture.  So, similar to annotation sets to some degree, I think it's necessary to have more defined views...but, I'm not sure and don't want to create a bunch of views if they aren't really needed.
      So...lets take the OOB plan view called "Electrical Plan View".  To me...you need an electrical plan view for each floor?  Can a guru chime in and tell me if I'm on the right path?  I know you can select "any floor" in the plan view DBX...and use the up and down arrows to move through the floors and the same "view" will be applied to each floor.  But...I think you may want to use a different ref set on each floor or maybe have some unique text or something.
      I'm not sure I know what I'm doing...this is why I'm asking.
