Aamir77 Posted September 27, 2018 Share Posted September 27, 2018 Hello, I am confused somewhere on how to bring back the FLOOR STRUCTURE and FLOOR FINISH options in room specification dialog as of now I am having just the CEILING STRUCTURE and CEILING FINISH options. Thanks in advance. Link to comment Share on other sites More sharing options...
tommy1 Posted September 27, 2018 Share Posted September 27, 2018 If you set up the defaults for floor structure and floor finish, just check the default boxes. If not, then you'll probably have to manually reset set them. Link to comment Share on other sites More sharing options...
Aamir77 Posted September 28, 2018 Author Share Posted September 28, 2018 As a hint, the place is not a perfect square rather it has angular walls for whom the plan is made. I have ignored the caution of angles of walls. May it be the culprit? Link to comment Share on other sites More sharing options...
