Benzarch1 Posted September 16, 2018 Share Posted September 16, 2018 I thought I had everything worked out on this house design. But when I opened it today to work on it the ceiling heights in the Utility room and the basement below are all screwed up and I can't change them. Any help ? Thanks in advance Floor_plans_-_Aug_2018.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted September 16, 2018 Share Posted September 16, 2018 Looks like it got Moved..... , it's good to have your Forum Signature filled in, especially with the Software Version, and of course a real Name is nice too .............. See mine below in Blue for how to do that. If you don't see my Signature then you have them turned off for the Forum so you need to Toggle it on by going to the Upper RH Corner of this Forum Window and Clicking on your Username and making sure Signature are enabled (green) and then Add your Own Sig. too : UserName> Account > Signatures M. Link to comment Share on other sites More sharing options...
