madcowscarnival 10 Posted September 6, 2018 I had to give up and send this back to the designer to change the roof plan. I really wanted to demonstrate to the designer and builder how quickly this could be mocked up in CA. The builder wants the covered patio roof removed, and that little modification mucks up a bunch of the roof lines in the back. I created the outline of the house and changed ceiling heights on rooms as needed. It also has 9:12 side pitch, 7:12 front to back. My attempt is in the .plan file. Some of the roof planes, even on 9:12 spec'd walls, auto-build at 7:12. The roof is a mess compared to the original designers. I'm pretty sure the designer just uses some manner of 2-D drawing program for his designs. He and the builder have had me model a couple for a "what would the interior look like" type question, this would really show off the programs ability. Any pointers would be greatly appreciated. elevs.pdf roof layout.plan Roof Print.pdf Share this post Link to post Share on other sites
solver 1636 Posted September 6, 2018 This has a bunch of manual changes, and isn't what the builder designed, but shows one way to handle removing the patio roof. roof layout (eric).zip 1 Share this post Link to post Share on other sites
madcowscarnival 10 Posted September 6, 2018 Wow, Eric, thank you very much. How did you handle that process? Modifying an auto-build or drawing main planes manually then cutting in the small planes. Its so much cleaner than anything I could create. I'm going to try and deconstruct in the AM and figure out how to do that myself. I'll also shoot an ortho of the rear view to them. Taking out the patio roof really changed the look of it, don't know if they've "seen" that yet. Share this post Link to post Share on other sites
solver 1636 Posted September 6, 2018 Here is a video going over the basics of what I did. Watch on YouTube: http://youtu.be/Q7dcEGJJRok?hd=1 1 Share this post Link to post Share on other sites
madcowscarnival 10 Posted September 6, 2018 Eric, In all sincerity you exemplify everything that someone could want in an online forum. Thank you. That was an extremely helpful video. I watched then worked through the steps on my own. I didn't realize how powerful the roof edge join tool was, I've only used it in basic situations. Share this post Link to post Share on other sites
Rashid_Garuba 27 Posted September 10, 2018 Eric... How to yo arrive at the 3D view with all textures off..? Share this post Link to post Share on other sites
solver 1636 Posted September 10, 2018 Technical Illustration 3D>Toggle Patterns Share this post Link to post Share on other sites
Rashid_Garuba 27 Posted September 11, 2018 Thanks..! Share this post Link to post Share on other sites
