RRFDesign Posted August 15, 2018 Share Posted August 15, 2018 Hello - I have Chief for Interiors 10. I want to create a circle countertop at the end of a cabinet run. This will be at 42" high - supported by a 3" partician, a wall cleat and a center post. It will be flat against the wall. Please see picture of a project have done in the past. I have tried creating a square, then breaking it and creating arcs at the segments, but it doesn't create a smooth circle. Thank you for your help. Link to comment Share on other sites More sharing options...
RRFDesign Posted August 15, 2018 Author Share Posted August 15, 2018 Wow - that was easy. Thank you. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 15, 2018 Share Posted August 15, 2018 A couple other thoughts just to put into your toolbox along with Eric’s suggestion... -You can fillet corners instead of converting lines to arcs. You can do this using the Filet tool or by using the Filet edit mode. If you start with a perfect square, you’ll end up with a perfect circle. -You can use countertops in convunction with actual circles (CAD) along with boolean operations (polyline union, polyline intersection, and polyline subtraction). Just select the countertop first. Link to comment Share on other sites More sharing options...
