BalsamKnoll Posted August 15, 2018 Share Posted August 15, 2018 I have invested way more time than I should have working on a plan that was created by my architect and is already under construction. I am looking for someone using Pro or Chief to correctly model the exterior and get it to the correct ceiling heights and roof lines. I will change all finishes (selection process underway) - I just need default finishes on a plan that follows the architect's. I'm not using the plans for framing purposes - trusses and framing are already done. A preview of the plans is attached. Actual plan has been drafted to interior walls but needs adjustments for rear shed dormer on the rear of the house, front bump out, and the screen porch has not yet been added. Link to comment Share on other sites More sharing options...
javatom Posted August 15, 2018 Share Posted August 15, 2018 OK I'll be the one to ask the obvious question. Why don't you have your architect do this for you? Link to comment Share on other sites More sharing options...
BalsamKnoll Posted August 15, 2018 Author Share Posted August 15, 2018 He doesn't use CA (DATA CAD). I'm able to get CAD files, but as I understand it, they don't translate into CA, correct? Link to comment Share on other sites More sharing options...
QuadraCadDesigns Posted August 16, 2018 Share Posted August 16, 2018 Hello, I saw your post on upwork and now here. I'm interested in discussing this project with you. Lee Trahan (207)509-8453 Link to comment Share on other sites More sharing options...
