scout1 Posted August 4, 2018 Share Posted August 4, 2018 any way to get a symbol created using the drop down box (geometric shape ) to go to a schedule Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 4, 2018 Share Posted August 4, 2018 There is no Geometric Shape schedule so you need to use a different schedule type. This means you have to either use a different Symbol Category (one that has a schedule) or you need to block your symbol after you create it, open the block, check Treat as One Object, and select the desired object type under Include In Schedule. Link to comment Share on other sites More sharing options...
scout1 Posted August 4, 2018 Author Share Posted August 4, 2018 why would chief let you create a symbol typ ( geometric shape ) that could not go to a schedule? does not make much sense that they would create an unusable category. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 4, 2018 Share Posted August 4, 2018 3 minutes ago, scout1 said: why would chief let you create a symbol typ ( geometric shape ) that could not go to a schedule? does not make much sense that they would create an unusable category. That's only true if your sole purpose for creating a symbol is to add it to a schedule. There are plenty of other reason to use symbols though. Link to comment Share on other sites More sharing options...
scout1 Posted August 4, 2018 Author Share Posted August 4, 2018 that was not the point all of the other categorys in symbols type will go to a schedule so I thought this was no exception my mistake Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 5, 2018 Share Posted August 5, 2018 1 hour ago, scout1 said: that was not the point all of the other categorys in symbols type will go to a schedule so I thought this was no exception my mistake Sorry, this is simply not true. Cabinet Door/Drawer symbols will not, Door symbols will not, Geometric Shapes will not, Hardware symbols will not, Millwork symbols will not, Molding symbols will not, and Sprinkler symbols will not. Note that a few of the above will report to a schedule when included as accessory parts of a parent object, but for all intents and purposes, less than half of the symbol types will report to a schedule like what you're looking for. Link to comment Share on other sites More sharing options...
