Elsayed Posted August 2, 2018 Share Posted August 2, 2018 Hi all, i need help to make wall with different thickness, the attached screenshot showing the problem, the interior layer of the wall doesn't cover the main layer at the joint place, Any suggestions to solve this problem? Thanks. Link to comment Share on other sites More sharing options...
javatom Posted August 2, 2018 Share Posted August 2, 2018 You may need a new wall type. Copy an existing one, re-name it and adjust the thickness to what will work for you. It may help us all to get a better description of what you are trying to do and what software you are using. Link to comment Share on other sites More sharing options...
Elsayed Posted August 2, 2018 Author Share Posted August 2, 2018 On 8/2/2018 at 12:30 AM, solver said: Expand Perfect, How can this be done? Link to comment Share on other sites More sharing options...
