different wall thickness problem
Elsayed
Hi all,
i need help to make wall with different thickness, the attached screenshot showing the problem, the interior layer of the wall doesn't cover the main layer at the joint place,
Any suggestions to solve this problem?
Thanks.
You may need a new wall type.  Copy an existing one, re-name it and adjust the thickness to what will work for you.  It may help us all to get a better description of what you are trying to do and what software you are using.
