Adding additional symbols to electrical legend
desiblu
I am adding an electrical legend into my layout, and realized that all of the symbols that I used for custom lighting, etc. are not in the legend.  I tried pulling in an electric schedule with the idea of breaking it, then using the symbols to add to my legend, but it wont do that.  Is there another way to bring in the correct symbols from my plan into an electrical legend?
If you are making a manual legend you can Insert the electrical cad blocks from CAD Block Management.  However if you are using one of the more recent versions you can add the 2D Symbol to the Electrical Schedule as a column. There is also a Electrical Legend in the Library as a cad block that you can edit.
    30642
    oppguenard1
    oppguenard1
  • Similar Content
    • By Renerabbitt
      POST 0
      You've found it! A thread offering up some of my favorite symbols and content for Chief Architect X-11 and X-12.
      These items are for X-11 and X-12 only. If you haven't updated yet I encourage you to do so, it's a great release.
      The following content is listed by category with both a link to the post within this thread for easy navigation and a link to a direct download if you won't to cut straight to the chase. new/recent uploads are in RED font
      CLICK ON THE "DL" FOR INSTANT .CALIBZ DOWNLOAD:
      CONSTRUCTION ASSEMBLIES/ARCHITECTURAL ITEMS:
      RABS 42 CABLE RAILING - DL    RABS MODERN FRONT DOOR AND DOOR ASSEMBLY - DL   RABS INTEGRATED SINK - DL NEW!!! 03/26/2020
      ENTOURAGE:
      RABS CHARLES-HILL GROUPED LIVING ROOM - DL RABS CHELTON GROUPED LIVING ROOM - DL    ACCESSORY HOME #1 - DL ACCESSORY HOME #2 - DL ACCESSORY HOME #3 - DL
      KITCHEN RELATED:
      3-ISLANDS - DL LA CORNUE 1908 RANGE - DL CAFE APPLIANCES, PAINTABLE(CORRECTED) - DL
      LIGHTING:
      PENDANTS AND SCONCES - DL-1 - DL-2 - DL-3 - DL-4 RECESSED NC HALO 4 INCH LED WITH HOUSING - DL NEW!! 03-22-20
      MATERIALS:
      TILE AND COUNTERTOPS #1 - DL 1(ONEDRIVE LINK) - DL-2 CUSTOM WHITES WITH PAINT TOOLBAR ICONS - DL-1 - DL-2 - DL-3 - DL-4 - DL-5 - DL-6 RABS RUGS 1V1 - DL          RABS STARTER KITCHEN MATERIALS PACK - DL         RABS FLOORING PACK 1 - DL            RABS OLD GOLDEN OAK FLOOR - DL
      SYMBOLS:
      FIREPLACE ASSEMBLY 1 - DL     FIREPLACE STACK TOOLS - DL ACKLES BED AND EDISON TABLE LAMP - DL-1 - DL - 2 TEAPOT MATERIAL EDITOR REPLACEMENT - DL-1 - DL-2 FINMARK TABLE FROM CB2 - DL FIREPLACE MANTLES 1 AND 2 - DL    RABS STRETCHABLE PICTURE FRAMES - DL    BATH SURROUND TOOLS ARCHED CABINETS -DL Rabs Cat Tree
      VIDEOS:
      YouTube Channel
      Many of these I have personally made or modified. Some of the content may have been created by others for which I will give credit. Many of the materials have free licensing, so no credit is needed.
      Some of this content may slow down your program as I have a high powered machine and often times use complex and high resolution textures. I will try and give as much detail as possible. Use at your own peril!
      No but seriously dig through and enjoy, I've spent a good number of hours ensuring the quality of these symbols and will update them periodically- so CHECK BACK IN! and PLEASE GIVE A LIKE FOR THE POST OF ANY SYMBOL YOU LIKE, IT ENCOURAGES ME TO GO BACK AND REFINE/REDUCE/OPTIMIZE THAT SYMBOL. GIVE A DOWNVOTE AND IT'LL PROBABLY ENCOURAGE ME TO DO THE SAME THING...YOU'LL JUST BE A JERK FOR IT
      CHANGELOG:(PACIFIC TZ)
      Page 1:
        Post 0:
      02-12-2019- 4:45PM: Removed the poll, migrated this thread. re-uploaded from X11 public beta 02-20-2019-2:59PM: Added a Poll for user content requests 03-30-2020-6:49PM: Deleted Video Links and added link to YouTube Channel   Post 5:
      02-12-2019- 4:45PM: centered the hearth on the symbol   Post 18:
      02-12-2019-9:52PM: Posted and fixed DL links Fireplace Stack
      01-05-2022-fixed broken links
      Here is a symbol to get you started:
      @Cheryl_C_Crane Think you requested this,
      RUSTIC BRICK 2.calibz
      Number of Textures: 2
      Map size: 1024x1024
      Filesize: 3.13 MB
    • By DRyeHD
      I would like to be able to display a dishwasher and disposal outlet in the position shown on the attachment (back of the cabinet).  The way I got this to work is to insert a wall, place the outlet, make it invisible, and turn off the invisible wall display.  Is there an easier way?  Outlets can be placed on the side of the island cabinet, why not on the back?
    • By MarkMc
      Updated 2/28-added cabinet doors into schedule-one on it's own floating and example of it on a cabinet.
      Changed the corbel procedure-instead of specifying the symbol should be "inside" the cabinet I now embed the "holding cabinet" into where the corbel goes. This allows proper vector and watercolor views. Revised plan attached
      I finally found a way to get millwork into the cabinet schedule without using architectural blocks. Problem with blocks is the dimensions read based on orientation in the space and not on the object.
      It's a bit of a futz at first but I'm happy. Once set up the stuff can live in the library.
      Place the millwork in a new plan, convert to symbol _CABINET DOOR instead of millwork. You will have to work with the origin and stretch zones. Origin will vary if it is going in as inset or trad overlay.
      Then place a cabinet, futx with the dbx (most need to have opening for back and both sides) In 3d vector view I change the sides of the cabinet to "opening no material"
      Once cabinet is done save to library- can later add a different millwork door to it to save work.
      Plan shows a schedule, two millwork "doors" and a couple of cabinets using them for reference. Open all dbxs to get the idea. (no not doing a video)
      I also placed at the bottom of the plan what I've been doing to get moldings, loose accessories, touch up kits, toe kick etc into the cabinet schedule. These are also saved to the library for reuse.
      The Text callout is placed once and copied. Dimensions can be adjust to read properly but the quantities are off so I put that into the label.
      Bracket sch.plan
    • By rfantclt
      I have a commercial project - historic hotel renovation & addition. My plans are set up with finishes, walls, etc., based on CA library of materials.  I want my Room Finish Schedule to use generic descriptions such as "cpt" for carpet, LVT, PCT, HDWD (hardwood floors), etc.  What is the best way to over-ride the materials I selected in defaults?
      Rebecca Fant, AIA
      Charlotte, NC
      rfant@archmatters.com
      x12
    • By ChiefuserMathews
      Could someone help me out to add a custom column heading to a schedule so that I can add some text to that schedule?
