CABINET SCHEDULES- fillers, panels not included
Andrew
X9   X8 user here
I'm learning how to use schedules for doors and windows, with some success.
I thought I would use CA to help write a cabinet schedule too, but the DBX for fillers and panels doesn't offer the checkbox to "include in schedule".
What do other users do?  Is there a way to include them in the schedule, or do you just write those manually?
Which does lead to a side question:  I'm trying to figure out how to edit the door schedule in the comments column, but nothing seems to work.
Any comments on that?
Thank you
18 minutes ago, Andrew said:
X9 user here
Thank you
What version are you using? It's a good idea to include that and some computer information in your signature.
are you using Chief Architect? or one of the Home Designer products? I ask because fillers have been included in schedules in Chief since I've used it (X3). Partitions were added in X10. I used to (and often still do) make partitions from cabinets and then keep them in the user library. Since I have a different approach to fillers I make those too but ..attached are screen shots from X10 -fillers, partitions, and comments in  doors.
Thanks Mark!
I am using X9 on a Win10 machine.
I also use my iMac at home, I think it's on High Sierra
I've added some of this data to my profile, at your suggestion.
I did find the cab fillers do have the "show in schedule" check box
But in X9, it appears they haven't thought of including panels yet : (
I haven't added mouldings yet, so I'm not sure about those.
In X9, I looked at the door DBX until nearly blind, then found the components icon can access some of the fields that post to the door schedule.  So, it's a work around, but it's something!
You want the Object Information Tab,OIP.thumb.png.9c5cfe512ac12e1bef3b9a99e545c049.png
then type in comments and such there.
The OIP fields made available in X9 are much easier than dealing with the components dialog.
Attached is a plan with a partition made from a cabinet- it will then show up in the schedule.
Moldings are a nogo:( I've used assorted work arounds for that and have posted on those in the past in tips and or symbols (memory fails). I need to order molding with the cabinets so this has been a BIG DEAL for me (Chief?) AND I only use molding lines for cabinet molding.
How I'm doing them lately is with cabinets as follows:
set to dimensions of molding; no fill; 0" separation, 0" reveal, materialis "Opening (no material)", set on their own layer, layer line style is blank (scroll down to the gap in the line list), line color white, label is whatever I need, finally I set it to be somewhere in the floor structure. (careful if you have to modify floor framing though). I keep an assortment in the library in a folder just for "schedule items".
You can either type in a quantity to one of the OIP fields OR append qty to label OR copy and paste in place to get the quantity.
Nice to know what version and such- add that to your signature so you don't have to keep being bothered. Makes it easier to help and troubleshoot-couple of the regulars post instructions on what and how to do it (Chopsaw ? Solver? Kbird?...) but they're all more tolerant than me :) I'm of the RTD school. Pretty sure there is a listing in the sticky for the forum by Dan too.
Partition.plan
