dimension on top
robymore
Is there any way to get dimensions to be the top drawing group without having to change the drawing group levels of the items which are on top of the dimensions , using X5. Just would like to tell the manual dimensions to be the top drawing group. Any ideas would be very helpful many thanks Rob
I haven't used X5 in quite a long time so I can't tell you definitively, but I don't believe there was any way to do that prior to X9.  Now we have a default setting for the drawing group.  If you use Chief regularly for a living, I would really recommend you upgrade.  There's a lot you're missing out on.
