Flippin' Walls
ebdesign
Chief will flip exterior walls when it thinks that you have an "outdoor" room type & an "indoor" room type & the exterior wall is reversed from what Chief thinks it should be. It usually happens when one of the rooms has not been named yet. Very annoying, especially when it automatically flips the wall about it's extremities instead of about the main layer. I'm sure you have seen that dbx that says something like this......."This wall appears to be backwards.............." & then displays a circle where the wall is.  Hopefully you're on the correct floor when you see the circle.The circle could be off-screen too.
