ebdesign Posted August 18, 2014 Share Posted August 18, 2014 Is there any way to stop Chief from flipping walls automatically? Man, is that irritating! It wouldn't be so irritating if Chief flipped the wall about it's main layer instead of it's overall width. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 19, 2014 Share Posted August 19, 2014 I'm not sure what you're referring to...can you be a little more specific? I'm not having any issues with walls flipping. Link to comment Share on other sites More sharing options...
ebdesign Posted August 19, 2014 Author Share Posted August 19, 2014 Chief will flip exterior walls when it thinks that you have an "outdoor" room type & an "indoor" room type & the exterior wall is reversed from what Chief thinks it should be. It usually happens when one of the rooms has not been named yet. Very annoying, especially when it automatically flips the wall about it's extremities instead of about the main layer. I'm sure you have seen that dbx that says something like this......."This wall appears to be backwards.............." & then displays a circle where the wall is. Hopefully you're on the correct floor when you see the circle.The circle could be off-screen too. Link to comment Share on other sites More sharing options...
