Tile Material help
brushpark
I am struggling to create a tile material with the attached image.  This is usually very easy for me, but I am having issues, does anyone know how to make this image work as a wall tile material?Thanks in advance!
 The reason you are having a hard time with that because it’s not a tile-able pattern as it is.  You need to take that center row of tiles (or equivalent) and copy it to the top or bottom.  Then you will have a pattern that can be tiled...after cropping the 2 nubs on the right and moving them over into the voids on the left that is... oh yeah, and then doing the same things to the ones on the top/bottom.
