Shower Wall at 45 degrees to Interior Wall troubles
Cheryl_C_Crane
I'm sure that this is User Error, but I've watched  https://www.chiefarchitect.com/videos/watch/2429/stacking-railings-to-create-a-glass-shower-enclosure.html several times and still can't fix this.
I've tried reversing the wall layers & redrawing using the old Glass Poly Solid on a Half Wall. Each time I have similar results. That 45-degree edge looks awful! Sorry the zip file took the 25 mb and left no room for little pix.
Mark_Green_Plan_C.zip
Thanks, Again, Eric.
It looks like 2 separate molding lines are needed: 1 for the Base and 1 for the crown. I futzed with the little p-solid earlier and noticed that the invisible wall lines will actually move about a 32nd if you have to pull back an Interior 4 and then bring it forward again. Like you, I had to move the invisible walls several times while trying to align the p-solid. So much for a quick work-around by saving to the Library.
