amddrafting Posted May 1, 2018 Share Posted May 1, 2018 So it was either version X8 or X9 I was having issues with line weight information exporting to a .DWG file when trying to export a plan to send to an architect. Has this issue been resolved with X10? Does anyone have autoCAD or a version that can import .DWGs that can verify that I'm not the only one that has had this issue or can anyone just answer that this is CA's standard M.O.? Thanks in advance. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 1, 2018 Share Posted May 1, 2018 I am also new to this and was wondering the same thing but recently got a free copy of Auto Desk DWG Trueview and you may be able to use it to find your answer. https://www.autodesk.com/products/dwg/viewers Link to comment Share on other sites More sharing options...
amddrafting Posted May 1, 2018 Author Share Posted May 1, 2018 Thanks, I'll check it out. I was unaware that the information didn't export until the architect responded after I sent his detail back and he was furious that all of his line weight information had disappeared. All line weight colors and thickness import correct into CA but I've been unable to figure out how to get it to retain the information during export. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 1, 2018 Share Posted May 1, 2018 It appears to be working with X10 but I am a long way from being an expert on this subject. Would be good to hear from someone who knows both softwares well. Link to comment Share on other sites More sharing options...
amddrafting Posted May 1, 2018 Author Share Posted May 1, 2018 Yeah that looks right! Thank goodness that was fixed. It's was a huge barrier with working with other design companies. Link to comment Share on other sites More sharing options...
