Exterior Vertical & Horizontal Studs for Wood Siding
boxerprod
Hi everybody ,
I have a vertical wood siding on a house.
In order to install it , i need a set of vertical studs 16OC , then a set of horizontal studs 24OC , and then the wood siding (vertical).
Is there a way to see the horizontal studs ?
Also , can these studs go through floor platform , from bottom to roof ?
Hope i'm clear enough.
Here a picture similar to what i'd like to get .
Thank you everybody for your help
