hagoodhomes Posted March 22, 2018 Share Posted March 22, 2018 Job Summary: Seeking a qualified drafter to join our residential building design department. Experience in Chief Architect is required . The drafter will successfully use Chief Architect to create detailed plans and 3D renderings for all new construction projects. This position is an integral part of our team! Responsibilities: -Coordinates with designer and sales person to produce construction documents for new residential construction -Draws detailed scale plans for foundations, buildings and structures, based on preliminary concepts, sketches or specification sheets -Creates 3D renderings of all projects, implementing customer provided design concepts and ideas -Maintains a working portfolio for each project that contains detailed layout and 3D renderings that will be presented to the customer for review -Coordinates with design team on all phases of the project including plan changes and revisions -Stays up to date and current on building codes and industry standards to determine their effect on each project -Identifies and resolves readily identifiable, clearly defined problems -Communicates with supervisor concerning progress or problems in an assigned task -Performs other duties as assigned Qualifications and Skills: -Must have advanced skills with AutoCAD, Chief Architect, & Microsoft Office Suite -Minimum of 3 years’ experience drafting and using Chief Architect -Working knowledge of construction and current building codes is required -Strong communication and organization skills are required -Skilled in multitasking, prioritizing, and time management -Able to work in a fast paced environment -Experience with BuilderTrend preferred -Construction field experience a plus Benefits: Competitive salary, health insurance, & 401-K Job Type: Full-time Location: Eastern North Carolina Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 22, 2018 Share Posted March 22, 2018 You should add where your from. 1 Link to comment Share on other sites More sharing options...
Dave13 Posted March 23, 2018 Share Posted March 23, 2018 Location shows Eastern North Carolina Link to comment Share on other sites More sharing options...
moonarch Posted March 29, 2018 Share Posted March 29, 2018 Hi, I am interested in the vacancy you have shared. I have near about 7 years experience in chief architect. I have worked on mostly residential projects.Please let me know the details about what I have to submit as I m from Asia. Link to comment Share on other sites More sharing options...
