Dynamic text line splines using distribution paths
Renerabbitt
First create a text box and then create a white, closed poly-fill box. Block the two together and add to your library as the text you typed.
draw a poly line and use the convert-to tool.
convert to a distribution path and select your cad block as the distribution object. simple!
    30739
    Dale8804
    Dale8804
