annechloe Posted January 23, 2018 Share Posted January 23, 2018 hi, I need help pls making the boarder on the paver like in the picture. I'm using X9. I don't know how to make the brick angled and distributed evenly like in the picture. when I apply the material it just wrap around the boarder which gives different angles on top and side view. Link to comment Share on other sites More sharing options...
NRST8TRKR Posted January 23, 2018 Share Posted January 23, 2018 Haven't tried this but how about a molding polyline with the appropriate shape and material. Have a great evening,Ken Also add a signature with your name, ver. of chief and your system specs. Link to comment Share on other sites More sharing options...
annechloe Posted January 23, 2018 Author Share Posted January 23, 2018 29 minutes ago, NRST8TRKR said: ntHaven't tried this but how about a molding polyline with the appropriate shape and material. Have a great evening,Ken Also add a signature with your name, ver. of chief and your system specs. hi thanks, it is spline polyline that I converted to solid and has irregular shape. I'm stuck since yesterday, I called the support but couldnt really help me. I'm new to chief architect premier x9. I'm learning it for a week now. what do you mean by adding signature, I assumed that my name is already displayed. not sure though. Link to comment Share on other sites More sharing options...
NRST8TRKR Posted January 23, 2018 Share Posted January 23, 2018 Top right cornet,click on your user name and go to profile and fill out info. use mine as a guide. Ken Link to comment Share on other sites More sharing options...
annechloe Posted January 23, 2018 Author Share Posted January 23, 2018 thnks ken. I will figure it out later:) Link to comment Share on other sites More sharing options...
DavidJames Posted January 23, 2018 Share Posted January 23, 2018 What about just using a spline distribution path? Link to comment Share on other sites More sharing options...
annechloe Posted January 24, 2018 Author Share Posted January 24, 2018 1 hour ago, DavidJames said: What about just using a spline distribution path? hi david, wow this is it!! how did you make it? I just watched the video and folled the steps but I have no access to the bricks Link to comment Share on other sites More sharing options...
DavidJames Posted January 24, 2018 Share Posted January 24, 2018 Anne - you can create your own block symbols and use those. I created the ones in the image I attached above. Link to comment Share on other sites More sharing options...
annechloe Posted January 24, 2018 Author Share Posted January 24, 2018 thank you so much , I just created the symbol just one more question. did you draw the sidewalk and the spline distribution path separately? I use different method for my current boarder and I cannot convert it into the distribution path. I'm going to delete the border nowbut how can I draw the distribution path parallel to my sidewalk which very irregular in shape? I really appreciate you r help David. Link to comment Share on other sites More sharing options...
DavidJames Posted January 24, 2018 Share Posted January 24, 2018 17 minutes ago, annechloe said: thank you so much , I just created the symbol just one more question. did you draw the sidewalk and the spline distribution path separately? I did. For the brick border, I used a distribution line, and for the walkway I just used a regular polyline solid Link to comment Share on other sites More sharing options...
annechloe Posted January 24, 2018 Author Share Posted January 24, 2018 thanks a lot . Link to comment Share on other sites More sharing options...
DavidJames Posted January 24, 2018 Share Posted January 24, 2018 My pleasure ☺️ Link to comment Share on other sites More sharing options...
