Anyone near Louisiana - Drafting Help Needed
Member Statistics
Similar Content
By BlackDiamond
I have over 8 years experience with Chief Architect (currently using X14) and have worked on various projects from simple starter homes to extravagant estates, multi-family projects, production homes, and resort communities. I currently live in Oklahoma but have worked remotely very successfully for many years. I would appreciate the opportunity to discuss with you how I might be of assistance on your next project. Please email me at blackdiamonddesign4@gmail.com.
Valley concept.pdf
By wazzubrad
I am trying to learn how I can get Material Lists or Schedules with Material List info, to export to Layout. I am trying to add some value to my drawings to make it easier for my guys to do takeoff's. For example; create a schedule that shows, Material Type, Qty, Description, etc. and then export that to Layout. I have found that although we can generate a Material List with this information, the Material List (AFAIK) can't be exported to Layout. If that is indeed true, then how can we get this information to show up on a Schedule? Specifically, I am trying to get my roof shingles to show up on a Custom Schedule. Any ideas on how I can tackle this?
By Arch_Tech
Hello all,
I am using CA X13.
I am designing a house that has a wing that is at 45 degrees relative to the other wing of the house. I am working with a Home builder and he has shown me that when a house is at 45 degrees, typically the elevation views reflect that by only showing the outline of the structure that is set at 45 degrees, like this.
As you can see the garage portion is at 45 degrees relative to the elevation view. I am pretty sure this set was produced with AutoCAD.
How can I make this happen in CA?
Thanks in advance!
By Renerabbitt
I offer some of the fastest turnaround in the industry on LARGE complex projects. Need a model built? A rendering complete? Elevations? A fully hosted 3d model to walk through?
Let me be your first stop to solving your urgent needs.
Created in Chief Architect X-13 in less than a day
Other Offer Services Posts:
