Sign in to follow this
gdhb20
Basement floor
I have a basement floor that is level with the footing. Is it possible to show that in a section view or somehow force the floor to be level with the footong?
Not sure about doing it automatically, but you could unselect Floor Under This Room and draw in your own slab.
You could do it like Eric said or do it automatic and raise the footing manually in elevation view. If you do it automatic then you must make sure your room height is correct for the foundation/stem wall default as you will essentially be shrinking it's height by manipulating the footings. only little thing you will need to do is pull back the floor cad box after you auto detail.
    27475
    slickrick1530
    slickrick1530
