ChiefQ Posted January 8, 2018 Share Posted January 8, 2018 Good day, I am fairly proficient with the program and sometimes have the weirdest wall issues. I cannot get rid if this hole in the wall, and for some reason I cannot manually edit these walls to make the hole go away. Any tips would be appreciated. Bateson,_John_-_2018_-_Garage_Option_05.plan Link to comment Share on other sites More sharing options...
dshall Posted January 8, 2018 Share Posted January 8, 2018 24 minutes ago, solver said: Put an exterior wall there, and mark it Roof Cuts Wall at Bottom. Or, if you want a wall in the lower area too, use the Lower Wall Type When Split By Butting Roof setting. I have a feeling you did not try your solution. If you asked me, this plan is a bit of a mess, yet interesting. 1. He adjusted many of his wall heights manually, not a good idea unless you know what you are doing 2. the wall is not there because his stairs are on top of wall 3. I think he is missing a staircase from the garage to the next level up....... This is a relatively complicated model. Link to comment Share on other sites More sharing options...
dshall Posted January 8, 2018 Share Posted January 8, 2018 Nice job E Link to comment Share on other sites More sharing options...
ChiefQ Posted January 9, 2018 Author Share Posted January 9, 2018 You guys are so awesome! This is perfect. Thank you so much. Link to comment Share on other sites More sharing options...
