Cabinet feet or legs on one side only
RGAID1
  • 6 years later...
Nor sure what Eric's answer was, but as long as you don't have "always present" checked, the program should already work the way want.
If this is not working for you, then you probably need to post your plan.
I figured it out, My cabinet was freestanding. If it was against a wall or other cabinet it only has 2 legs in the front. So an invisible wall or cabinet behind it does the trick...
