Design74Care Posted July 18, 2014 Share Posted July 18, 2014 Hi I have recently bought a hood fan and when I try to import it I am having difficulty. (first time with a 3d model) I went into the import and downloaded the- DB_Apps_Tech_07_05_OBJ.zip (195 KB) I can not find it through the File import. I am hoping someone can help me. these are the options. Curved Glass Chimney Hood 3D Model Files DB_Apps_Tech_07_05_LWO.zip (208 KB) DB_Apps_Tech_07_05_LXO.zip (215 KB) DB_Apps_Tech_07_05_C4D.zip (271 KB) DB_Apps_Tech_07_05_OBJ.zip (195 KB) DB_Apps_Tech_07_05_MAX.zip (347 KB) DB_Apps_Tech_07_05_FBX.zip (588 KB) Thanks My program. Home designer suite 2014 Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 18, 2014 Share Posted July 18, 2014 No Chief Architect or Home Designer title imports "Zip files" (compressed archives), you first decompress or un-zip the downloaded files and then IF those files are in a file format that the software does import you can then import and use those symbols (check the " File - Import Symbol" dialog for which files are acceptable. DJP PS: BTW this forum specializes in end users of Chief Architect Premier only, there is a specific user forum for Home Designer Users called "Home Talk", I suggest you use that forum in the future. Link to comment Share on other sites More sharing options...
