Importing 3D Model
Design74Care
Hi I have recently bought a hood fan and when I try to import it I am having difficulty. (first time with a 3d model) I went into the import and downloaded the- DB_Apps_Tech_07_05_OBJ.zip (195 KB) I can not find it through the File import.  I am hoping someone can help me.
these are the options.
Curved Glass Chimney Hood 3D Model Files
  • DB_Apps_Tech_07_05_LWO.zip (208 KB)
  • DB_Apps_Tech_07_05_LXO.zip (215 KB)
  • DB_Apps_Tech_07_05_C4D.zip (271 KB)
  • DB_Apps_Tech_07_05_OBJ.zip (195 KB)
  • DB_Apps_Tech_07_05_MAX.zip (347 KB)
  • DB_Apps_Tech_07_05_FBX.zip (588 KB)
Thanks
My program.
Home designer suite 2014
No Chief Architect or Home Designer title imports "Zip files" (compressed archives), you first decompress or un-zip the downloaded files and then IF those files are in a file format that the software does import you can then import and use those symbols (check the " File - Import Symbol" dialog for which files are acceptable.
PS: BTW this forum specializes in end users of Chief Architect Premier only, there is a specific user forum for Home Designer Users called "Home Talk", I suggest you use that forum in the future.
