Using The "control" Button To Move Objects.
SusanC
Go to solution Solved by SusanC,
Hi,
I just switched our office over from the pc version to the Mac version of X6 Premier and I'm discovering a few of the subtle differences.
On the pc version I could select an object and hold down on the "Control" button to move it where ever I needed to.  Does anyone know which key on the Mac will allow me to do the same?
Also, the scroll bars along the side and bottom are hiding and I can't seem to figure out how to get them to show.  I know this should be an easy answer, but I'm missing it!  Any suggestions?
Thanks!
Susan
The "Command" key on the Mac will give you the same functionality as the Control key on a PC.  To keep your scroll bars visible, go to the System Preferences, General and select "Always" on the Show Scroll Bars setting.
