mrrozhall Posted October 10, 2017 Share Posted October 10, 2017 Good Evening Folks, I cannot for the life of me figure out how to remove the tile shingles in the attached plan and change to regular composite shingles. This plan originally came from a design that used tile shingles, but I've since deleted that plan and create this new one. However, the tile shingles are still set somewhere. Sounds trivial but I can't figure out how to revert back to composite shingles. I'm using X8. Thanks Roz KIDD_RAMBLERIDGE.plan Link to comment Share on other sites More sharing options...
Chiefer Posted October 10, 2017 Share Posted October 10, 2017 10 minutes ago, mrrozhall said: Good Evening Folks, I cannot for the life of me figure out how to remove the tile shingles in the attached plan and change to regular composite shingles. This plan originally came from a design that used tile shingles, but I've since deleted that plan and create this new one. However, the tile shingles are still set somewhere. Sounds trivial but I can't figure out how to revert back to composite shingles. I'm using X8. Thanks Roz KIDD_RAMBLERIDGE.plan Try this and rebuild roof. 1 Link to comment Share on other sites More sharing options...
pintodesign Posted October 10, 2017 Share Posted October 10, 2017 or, select each roof plane and change the material there. Link to comment Share on other sites More sharing options...
mrrozhall Posted October 10, 2017 Author Share Posted October 10, 2017 Pinto and Chiefer, unfortunately, I do not see "Roof" under the Roof plan specification or when I Build Roof. I see Fascia, skylight, soffit and Ridge Cap. But no "Roof" by itself. Weird. Link to comment Share on other sites More sharing options...
mrrozhall Posted October 10, 2017 Author Share Posted October 10, 2017 Attached is what I see.... I don't see "Roof" Link to comment Share on other sites More sharing options...
mrrozhall Posted October 10, 2017 Author Share Posted October 10, 2017 Solver, PERFECT!!!!! THAT WORKED. THANKS SO MUCH SIR. ROZ Link to comment Share on other sites More sharing options...
