Need Help Converting
bobbijn
I can model your PDF into a .plan file using Chief Premier X6 (Suite 2015 and X6 are compatible) and then program that file to be editable in Home Designer Suite 2015. The only proviso I would suggest is that you NOT thereafter try to build roofs because Home Designer Suite is VERY INCAPABLE  in terms of creating roof systems. Let me know when you would like to get started. I charge $75.00 per hour. All I need is your PDF file and how you intend to use the resultant.plan file
